Show reports in power bi for problem list
chandan1994
Hello Team,
i have a requirement to show the report in power bi from servicenow problem table, please how to do this.
should i do power bi integration , if yes please provide the steps too as i am new to integration.
Thanks in advance.
Raks
I guess there some issue with the URL you are using:
Go to REST APi explorer and in there below the Prepare request option select the problem table from the drop down.
Click on the send button you will get a correct url for the request .
replace the url in code with the one you will get in the REST API explorer.
Remeber to change this part only.
https://<host>.com/api/now/table/problem
27 REPLIES 27
Tushar Hirpurk1
Mega Guru
Hi Chandan,
               You can connect to ServiceNow data from PowerBI Side by setting up the ODBC Connection.
find below link hope this helps:-
https://www.cdata.com/kb/tech/servicenow-odbc-power-bi.rst
Please mark reply as Correct/Helpful, if applicable. Thanks!
Tushar
Hello Tushar,
cdata licence will cost some amount, hence please advice if any other work arround
Anna Odrynska
Hello @chandan1994 ,
I see that you've already accepted the answer, but in case you're still interested in ServiceNow Power BI integration, feel free to check out our new app - Power BI Connector. I'll be happy if it will somehow be helpful to you.
Cheers,
Anna | Alpha Serve
