SLA Not Attaching for HR Case Created via Record Producer
RakshithS
Hi Team
I’m facing an issue where SLAs are not getting attached to HR cases that are created through a Record Producer.
When the HR case is created from the Record Producer, no SLA is attached initially — even though the record meets all the SLA conditions.
when I manually click on “Repair SLA” afterwards, the SLA then attaches properly for the records created through the Record Producer.
If I create the same type of HR case directly using the “Create HR Case” option from the application navigator, the SLA attaches correctly.
Can someone assist me on this ?
Could you please add a condition for Channel and Test? The channel is one of the values like this
RakshithS
This is a known issue in Zurich , workaround is available here https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB2552260
