Solution - Communication/Data Circuits in CMDb
03-25-2018 04:37 PM
Our Network and Telephony teams wanted a way to manage their circuits in the CMDB and be able to use them for things like Incident/Problem/Change Management. The existing circuit table in CMDB is for power circuits (contains fields like phase, max amps, and voltage) , so I created a new table with some additional fields to meet their needs. The new table is extended from cmdb_ci.
Below the process requirements are most specifics like field choice list detail.
Process Requirements
- Fields which are required to be populated to create a new record or update an existing record:
- Name
- Circuit type
- Circuit category
- Circuit ID
- Terminating device
- Support group
- Ability for members of IT Network Engineering or Telecom support groups to create new records
- Members of the set support group will have write access to the CI
- Users who are not members of these groups will have read-only access and will not be able to create records
- Circuit ID field is read only unless Lifecycle status is "In build"
Technical Requirements
- There are a few required fields that are custom to Circuits that were added from the base table. Those fields are:
- Circuit Type – Choice List with following values
- MPLS
- Internet
- P2P
- SIP
- PRI
- Circuit Category – Choice List with following values
- Corporate
- Partner
- Circuit ID – String field (text)
- LEC ID – String field (text)
- Port speed – Choice List with following values
- 10 MBPS
- 100 MBPS
- 1 GBPS
- 10 GBPS
- Circuit CIR – Choice List with following values
- 20 Mbps
- 30 Mbps
- 40 Mbps
- 50 Mbps
- 60 Mbps
- 70 Mbps
- 80 Mbps
- 90 Mbps
- 100 Mbps
- 200 Mbps
- 250 Mbps
- 300 Mbps
- 400 Mbps
- 500 Mbps
- 600 Mbps
- 700 Mbps
- 800 Mbps
- 900 Mbps
- 1000 Mbps
- 2000 Mbps
- 5000 Mbps
- 10000 Mbps
- Terminating Device – Reference field to allow a Network Gear CI to be referenced on a Circuit CI record
- Reference field is a lookup to Network Gear where the class is Router, Switch, Media Gateway, or WAN Accelerator
- Device Interface – Reference field to allow a Network Gear CI Network Adapter CI to be referenced on a Circuit CI record
- Reference field is a lookup to Network Adapter table. Is filtered to ONLY records related to the selected Terminating Device if one is selected
- Circuit Provider - re-labelled company field on this table
- 11,979 Views
01-27-2021 12:20 PM
There are some OOTB features that will get you started now.
Telecommunications Service Management (servicenow.com)
At the very least this document mentions a Network Circuit CI (cmdb_ci_network_circuit) which didn't exist 3 years ago, and would be a good place to start and preferable to a custom table.
I'm just researching this myself so not much advice yet on how to best use it.
02-26-2021 11:51 AM
There is a "Circuit" class that might be a good candidate for the information/fields as suggested by @cyked
06-21-2021 09:22 AM
This is Power Circuits not Data and all of these requirements would need to be added to that table. Is this still not a thing? Do people not track data circuits or do they do so in such an unrelated way that searching won't find the expected results?
06-21-2021 10:23 AM
hi all,
Check out the "Network circuit" table at cmdb_ci_network_circuit.
You may need to get some extra ci tables from a plugin to see it.
Rick
06-21-2021 11:30 AM
I checked for the table but it doesn't exist. Maybe we don't have the plugin enabled but I don't know which plugin that is. It seems that it may be part of Telecommunication Service Management but I'm guessing that's an additional paid module?
