04-07-2021 02:36 AM
i want to split the string from \n\n and converted it into json object in Business Rule script
"VM to be provisioned for which region? = APAC\n\nLease Type = Temporary\n\nStart = 2021-04-07 14:53:17\n\nEnd = 2021-06-06 14:53:19\n\nSize = Basic A0 | 1 Core | 768 MB\n\nUsed for = Development\n\nBusiness purpose = test\n\n"
04-07-2021 03:02 AM
try this
Script:
var str = "VM to be provisioned for which region? = APAC\n\nLease Type = Temporary\n\nStart = 2021-04-07 14:53:17\n\nEnd = 2021-06-06 14:53:19\n\nSize = Basic A0 | 1 Core | 768 MB\n\nUsed for = Development\n\nBusiness purpose = test\n\n";
var arr = str.split('\n\n');
var obj = {};
for(var i=0;i<arr.length;i++){
var str1 = arr[i];
if(str1){
var arr1 = str1.split('=');
var key = arr1[0].trim();
var value = arr1[1].trim();
obj[key] = value;
gs.info(JSON.stringify(obj));
Output:
[0:00:00.065] Script completed in scope global: script
Script execution history and recovery available here
*** Script: {"VM to be provisioned for which region?":"APAC","Lease Type":"Temporary","Start":"2021-04-07 14:53:17","End":"2021-06-06 14:53:19","Size":"Basic A0 | 1 Core | 768 MB","Used for":"Development","Business purpose":"test"}
04-07-2021 03:48 AM
@ankur
everything is fine just I want output :
{"VM to be provisioned for which region?":"APAC"},{"Lease Type":"Temporary"},{"Start":"2021-04-07 16:01:12"}
what need to make changes.
04-07-2021 03:54 AM
Then ensure the loop runs only till 3 and not complete length
for(var i=0;i<3;i++){
