Split the value from look up select box field and auto populate in single line text variable
satya30
I have a look up select field where I am populating the values of u_code, u_label by seperator (u_code|u_label)
then I have a single text variable which is read only where I need to auto populate the u_code that is getting displayed in the look up select box field.
Here, I cannot change the Look up select box to Reference field.
Thanks in advance.
9 REPLIES 9
yeah i am getting the sys)id of the record in info message
I am not allowed to change the variable type here.
please help me with GlideRecord and get the value of field u_code from that table
I tried and it is not working for me.
sejal1107
Hi @satya30
Please try below code
    if (isLoading) return;
    // Get the selected value from the lookup select field (assuming it's 'u_lookup_select')
    var selectedValue = g_form.getValue('u_lookup_select');
    // Split the value at the separator (assuming format is u_code|u_label)
    var uCode = selectedValue.split('|')[0];  // Extract the u_code part
   alert(uCode);
    // Set the u_code into the read-only text field (assuming it's 'u_code_field')
    g_form.setValue('u_code_field', uCode);
If my response helped please mark it correct and helpful.
Thanks & Regards,
Sejal
I tried this way, this is storing the sys_id of the record in the code field.
what needs to be done here?
What is added in 'Lookup value field' for look up select field ?
instead of
try using
var selectedValue = g_form.getDisplayValue('u_lookup_select');
For me its showing properly
getDisplayValue works only for reference fields.
In the look up field it is take u_Code | u_label values to get displayed
