SSO issue after adding X.509 Certificates
Alok Sahu
We are using ServiceNow Fuji version after adding JAVA Key Store certificate in X.509 Certificate our SSO fails .
Error :
There was a problem accessing the site. Try to browse to the site again.
If the problem persists, contact the administrator of this site and provide the reference number to identify the problem.
Reference number: 24441569-5894-48b0-8c2a-abfc2134b0f1
Is this a Bug or Know issue in Fuji ?
Any work around of fix this issue.
Please help.
Hi Tony,
I have gone though below links :
http://wiki.servicenow.com/index.php?title=Multiple_Provider_Single_Sign-On#gsc.tab=0
http://wiki.servicenow.com/index.php?title=SAML_2.0_Setup#Step_5._Install_the_IdP_Certificate
As per Wiki SAML 2.0 plugin is required for single sign-on integration.
I don't want to integrate multiple single sign-on. My purpose is to integrated external system using SSL certificate.
I have added a new certificate for third-party SSL authenticate atX.509 Certificates and using the same in SOAP Message function for outbound call. After activating the certificate I am successfully able to post message via   SSL integration with the external system however it leads to SSO fails.
My question is why SSO is getting interrupted if I add one more certificate in ServiceNow for purpose of external integration ?
It seems like a bug .
-Alok
Hi Alok,
I think the best way forward is for you to raise an Incident with Technical Support via HI.
It seems that there is an issue here that needs detailed examination of the configuration.
Best Regards
Tony
Thanks Tony,
I have raised and Hi ticket it seems only after adding+activating a new certificate in X.509 Certificates the SSO fails without activating the certificate everything works fine.
-Alok
