08-29-2025 06:52 AM
Hi, is it normal that the state field in SOW for a problem is read only? When I click continue problem it takes me to native UI?
08-29-2025 07:07 AM
Usually state field will be read-only on PRB in SOW as compared to native.
Did you check which client script or UI policy is doing that?
Also "Continue problem" is an OOTB ui action which will take user to native. It's OOTB behavior.
08-29-2025 08:53 AM
Problem 'state' field is read-only in classic UI as well as workspace out of the box.
To make it editable, you have to disable UI Policy, Client Script and Dictionary over-ride. It is not recommended to change this behavior but below is for reference,
UI Policy - 'Make Problem State read only'
Client Script - 'Make Problem state readonly'
Dictionary Override - go to state field -> Configure Dictionary -> Open Dictionary Override table 'problem' base table 'task' and disable 'Override read only'
State field - Editable in Classic UI after the changes
State field - Editable in Service Operation Workspace after the changes
Revert the changes to make it back to read-only.
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
08-29-2025 06:55 AM
Hi @joshmorris
No, this is not expected behavior. Also, the continue problem is not OOTB—it’s a custom UI action that has been built in your instance. So, it’s hard to say whether the new state is read-only due to this customization or not, but OOTB it is not.
08-29-2025 06:58 AM
Ah this is strange. We have never used service ops workspace before so don't know how it has gone to that
08-29-2025 07:02 AM
08-29-2025 07:03 AM
Its the same in all 3 instances though
