State Field showing incorrect State
Mudit4
Kilo Expert
I have defined a Change Model consisting of:
Scheduled ->Implement, Pending Customer
Pending Customer-> Scheduled, Implement
Implement-> Review, Pending Customer
When I transition my change request into Pending Customer State, The state field shows 'Scheduled'. On checking the state in the List of change requests, the state is Pending Customer. Also, when the request is first loaded it shows Pending customer but Changes to 'Scheduled'
What is happening. I know the request is in pending state but why does the state value change to Scheduled.
But on opening-> State value initially is Pending but switches to "scheduled" on loading
Yes it is a custom state. I created it by following the same documentation you mentioned. I still dont know why the problem occured. But somehow it got resolved over the weekend without me making any changes
14 REPLIES 14
I see very weid.
But if its already resolved then it is good for you.
Please mark any answer as correct and close this thread as the issue is alresdy resolved
Also i just realized can you check the updated dates for the change modals and related configuration, maybe someone may have changed something
Okay I will check if there was any activity over the weekend
Hi Mudit,
go the state choice list and choose the value from there and set the value in the default value section and save then try to create the record once again and see it works.
