State Model and UI actions issues
mbayefdieng
Giga Contributor
Hi everyone,   cameronrichard ctomasi
I am working on the state transition of my Normal Change model, and am facing this issue.
When I modify the script includes ChangeRequestStateHandler and ChangeRequestStateModel_normal, I see all the UI actions visible on the form, and the state field shows all transition states.
these UI actions are visible as form buttons and list button,
What did I do wrong?
Script of ChangeRequestStateHandler:
var ChangeRequestStateHandler = Class.create();
// All references to statehandler constants should be through this class ChangeRequestStateHandler
ChangeRequestStateHandler.DRAFT = ChangeRequestStateHandlerSNC.DRAFT;
ChangeRequestStateHandler.ASSESS = ChangeRequestStateHandlerSNC.ASSESS;
ChangeRequestStateHandler.BUILD = "build";
ChangeRequestStateHandler.SCHEDULED = ChangeRequestStateHandlerSNC.SCHEDULED;
ChangeRequestStateHandler.AUTHORIZE = ChangeRequestStateHandlerSNC.AUTHORIZE;
ChangeRequestStateHandler.IMPLEMENT = ChangeRequestStateHandlerSNC.IMPLEMENT;
ChangeRequestStateHandler.CLOSED = ChangeRequestStateHandlerSNC.CLOSED;
ChangeRequestStateHandler.CANCELED = ChangeRequestStateHandlerSNC.CANCELED;
ChangeRequestStateHandler.prototype = Object.extendsObject(ChangeRequestStateHandlerSNC, {
      initialize: function(changeRequestGr) {
ChangeRequestStateHandlerSNC.prototype.initialize.call(this, changeRequestGr);
              This.STATE_NAMES["-6"] = ChangeRequestStateHandler.BUILD;
      type: "ChangeRequestStateHandler"
Script of ChangeRequestStateModel_normal
STATE_NAMES: {
              "-5": "draft",
              "-4": "assess",
            "-6": "build",
              "-2": "scheduled",
              "-3": "authorize",
              "-1": "implement",
              "0": "review", \\ not a used state
              "3": "closed",
              "4": "canceled",
var ChangeRequestStateModel_normal = Class.create();
ChangeRequestStateModel_normal.prototype = Object.extendsObject(ChangeRequestStateModelSNC_normal, {
      draft: {
              nextState: [ "assess" ],
              assess: {
                      moving: function() {
                              return this.toAssess_moving();
                      canMove: function() {
                              return this.toAssess_canMove();
              canceled: {
                              return this.toCanceled_moving();
                              return this.toCanceled_canMove();
      assess: {
              nextState: [ "build" ],
              draft: {//if technical approver requests more information
                              return this.toDraft_moving();
                              return this.toDraft_canMove();
              build: {
                              return this.toBuild_moving();
                              if(this._gr.getValue("u_needs_build")=="Yes") return true;
                              return false;
              scheduled: {
                              return this.toScheduled_moving();
                              if(this._gr.getValue("u_needs_build")=="No") return true;
                              return false;
              canceled: {
      build: {
              nextState: [ "scheduled" ],
              scheduled: {
                              return this.toScheduled_canMove();
              canceled: {
      scheduled: {
              nextState: [ "authorize" ],
              authorize: {
                              return this.toAuthorize_moving();
                              return this.toAuthorize_canMove();
              canceled: {
      authorize: {
              nextState: [ "implement" ],
              scheduled: {//if on hold
              implement: {
                              return this.toImplement_moving();
                              return this.toImplement_canMove();
              closed: {//if rejected
                              return this.toClose_moving();
                              return this.toClose_canMove();
              canceled: {
      implement: {
              nextState: [ "closed" ],
              authorize: {//if put on hold
              closed: {
                              return this.toClosed_moving();
                              return this.toClosed_canMove();
              canceled: {
      closed: {},
      canceled: {},
      toBuild_moving: function() {
                                                        return true;
      toBuild_canMove: function() {
                                                        return true;
      type: "ChangeRequestStateModel_normal"
mbayefdieng
Giga Contributor
there is a typo in the code of ChangeRequestStateHandler:
because of this capital T in this.
16 REPLIES 16
mbayefdieng
Giga Contributor
Getting an "invalid update" error then in Assess State and trying to move to the next. cameronrichard
another typo in code - I resolved this
