Submit Knowledge Article in Review state using UI Action
Uttam Sai
I have created a UI Action on Outage form which creates a KB Article using below script . The requirement is to Submit Knowledge Article in Review state , currently the KB Article is generating Draft state  . Could you please help me with the requirement.
Thank you
Uttam Sai S
var kb = new GlideRecord('kb_knowledge');
kb.initialize();
kb.short_description = current.short_description;
kb.text = current.details;
kb.insert();
Gunjan Kiratkar
Hi @Uttam Sai ,
You can use UI action as below :-
kb.initialize();
kb.workflow_state = 'review';
kb.insert();
There is on OOB business rule which change the workflow state of KB article as draft before insert. If you make it active false then your UI action will work.
The 2nd method is exclude the KB article created from UI action as below :-
UI action code :-
kb.initialize();
kb.text = "Article From Outage:"+"\n"+current.details;
kb.insert();
BR edit in condition:-
Please Mark My Response as Correct/Helpful based on Impact
Gunjan Kiratkar
2X ServiceNow MVP
Community Rising Star 2022
Youtube : ServiceNow Guy
9 REPLIES 9
Hi @Uttam Sai ,
Please try below script
kb.initialize();
kb.short_description = "Test SNOW COM";
kb.text ="Test SNOW COM";
kb.insert();
kb.update();
Please mark the answer as correct, If I answered your query. It will be helpful for others who are looking for similar questions.
Saurabh
Thanks and Regards,
Saurabh Gupta
@Uttam Sai
Have you tried above script?
Thanks and Regards,
Saurabh Gupta
Hi @Saurabh Gupta  ,
Thank you so much for your response . I have tried the above script but is not working as expected .
Gunjan Kiratkar
Hi @Uttam Sai ,
kb.initialize();
kb.insert();
UI action code :-
kb.initialize();
kb.insert();
Gunjan Kiratkar
2X ServiceNow MVP
Raghav Sharma24
Giga Patron
Try below, you need to update the state after creating the kb :
var x = new GlideRecord('kb_knowledge');
x.initialize();
x.short_description = current.short_description;
x.text = current.details;
var id= x.insert();
 var kb= new GlideRecord('kb_knowledge');
kb.get(id);
kb.state='review';
kb.update();
