Survey question mandatory on condition
sunilsargam
if survey question is 'are you satisfied or not satisfied'
and if use select Not Satisfied - then  "Give additional info" question comes which is mandatory
I want to show this question even if satisfied but in this case, it should be non mandatory.
Is this feasible in servicenow surveys
Tanushree Maiti
glideFather
Hi @sunilsargam,
do you use survey designer? I have done something similar in the SD yesterday.
You just create a question - "are you satisifed?"
Then another question "please explain", make that question mandatory and under the dependency tab you can select when to display that second question
brianlan25
I just created an idea for this as I'm looking to do something similar.
https://www.servicenow.com/community/itsm-forum/survey-question-mandatory-on-condition/m-p/3516785
