Switch views based on values of a field
Elena Pomana
I need to switch between views based on a field on the form.
The task is the following:
  • if field "Test" is choice 1 -> view should be "view 1"
  • if field "Test" is choice 2 -> view should be "view 2"
  • if field "Test" is choice 3 -> view should be "view 3"
I created a view rule that does that:
The problem is with new records, is it possible to change views in a new record based on the user's choice?
I tried to do the same logic in onChange client script but I need to save the record in order to display a view.
Thank you,
Elena
onChange CS doesn't work. It makes the user save the form first and we do not want that.
On a new record, onLoad won't be an option, because the field is -None- and when the user chooses an option it will enter a loop. Tried it for testing purposes and it kept refreshing the page.
Have a nice one,
Elena
that's correct.
