System property in ACL is not working
Bindhu1
I have created Create ACL  to give access to the 'New' button on the Related List for Catalog Tasks on the RITM form for specific group and catalog items.
Code works well when i give sys id of the catalog item directly but when i am storing the same sys id in system property and using in ACL script that time 'NEW' button wont be visible.
Here the code , Kindly help me how to achieve it from system property
//answer= (gs.getUser().isMemberOf('Administrative Business Center-Agents') &&
parent.cat_item=='7d2ded94db1b77002ed03df3399619e7');
// above line of code alone works good
var customSysId = gs.getProperty('testCat_item_sysid'); // Retrieve the 'sys_id' from the system property
gs.info("bindu AA " + customSysId); // log gives proper sys id
gs.info("bindu BB " + gs.getProperty('testCat_item_sysid'));
answer = (gs.getUser().isMemberOf('Administrative Business Center-Agents') && parent.cat_item == customSysId);
Expecting result;
Thanks in advance
@Bindhu1
answer = (gs.getUser().isMemberOf('Administrative Business Center-Agents') && parent.cat_item.getValue('sys_id').indexOf(customSysId) > -1);
17 REPLIES 17
@Ankur Bawiskar @Vishal Birajdar
Hi, thanks for your help.
ACL script works fine when i use includes()  method like below
answer = (gs.getUser().isMemberOf('Administrative Business Center-Agents') && customSysId.includes(parent.cat_item.getValue('sys_id')));
@Bindhu1
not sure it should have worked earlier as well as that script looks good to me
you can use indexOf() then
Hi @Ankur Bawiskar
Could you please give me an example how  indexOf() works here.
@Bindhu1
Vishal Birajdar
Hi @Bindhu1
Can you try using if-else.
var isMember = gs.getUser().isMemberOf('Administrative Business Center-Agents');
if ( isMember && (parent.cat_item == customSysId) ) {
answer = true;
answer = false;
Vishal Birajdar
ServiceNow Developer
- Socrates
