Transform Map Coalesce
beycos
Hello Everyone,
I'm importing data from a JSON file using a Data Source and Transform Map. I have two fields set as coalesce: x and y. These two fields always have values in the incoming data, and are mapped correctly. what I need to achieve is If a record already exists with matching x and y , but the existing record has a value in the date deleted field
So basically:
  • If Date deleted field is not empty, I want to bypass coalesce behavior and force insert.
  • If  date deleted is empty, normal coalesce behavior (update) is fine.
  • Any guidance or best practices are appreciated!
    Thanks in advance!
beycos
"Company": "SN",
"name": "X",
"dateDeleted": "2025-03-17",
"companyNumber": 123
"Company": "SN",
"name": "Y",
"dateDeleted": "",
"companyNumber": 456
I have a scheduled data import that runs daily using a Transform Map in ServiceNow.
  • The source field is: Company
  • The target field is: u_company
  • Coalesce is set to ✅ true on this field.
    I want coalesce to work normally in all case. Except when the matching record in the target table has dateDeleted filled.In that case, I want to bypass coalesce and allow a new record (insert) even if Company already exists in the target table. However , Even when the 'date_deleted' field is empty, it continues to insert when I schedule it
