Transform Script to show active/inactive users.
Andrew112
Mega Guru
Hello, I have a transform script on a table transform map that I want to go through all the users, initially set to inactive, and then set to active to make sure that only active users are in the User table everytime the User list is loaded from external source. (It is loaded every day at a set time)
I have the following:
onStart
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
var users = new GlideRecord('sys_user');
users.query();
var user = users.next();
while(user !== null){
	user.Active = false;
})(source, map, log, target);
onAfter
target.Active = true;
It has been 1.5 hours, and it is still running.
Is there any better way to accomplish what I am trying to do here?
Hi Andrew,
you need to identify the users and the roles
form the query from sys_user table the users you want and roles you need to check
copy that query and use in script as below
var query = 'nameINAbel Tuter,Suresh Parab^roles=itil'; // place your query here
users.setLimit(5); // for testing purpose
users.addEncodedQuery(query);
users.query();
users.setValue('active', false);
users.updateMultiple();
Mark Correct if this solves your issue and also mark 👍 Helpful if you find my response worthy based on the impact.
13 REPLIES 13
Yes I marked your answer as correct. Thanks so much!
AshishKM
Hi Andrew,
Inactivating all active user(s) through the data import transform map is not a good solution, If any user trying to login during the inactivated state they will redirected to  logout page.
Instead, use the column mapping along with coalesce ( i.e. user_name or employee number ) then only new record will insert and existing record will update if chances expected through the daily data feed.
users.query();
// either use updateMultiple
users.setValue('active',false);
or
// iterate the gliderecord resultset.
while (users.next()){
 users.active = false;
 users.update();
Ashish
Please mark correct answer/helpful for other if it helps you.
Thanks where would I put this?
Hi, Put this code in "Transform Map" onStart section.
Ashish
Please mark correct answer/helpful for others if it helps you.
