translated texte on employee center
ahmed-24
Giga Guru
Hello guys!
i try to translate this requests text on employee center with system_messages texts editing but the probleme that it dosn't change!!! have you any idea when i can translate it please! Thank you
@ahmed-24 Here is the answer
 Go to "sys_translated_text" table and click on new. Then select Table name as "Activity Configuration [sn_ex_sp_activity_configuration]" from drop down and language as your target language example "French".
In the "field name" select "Activity Name" and in the value select the translated value you want.
In the "document" field select the target field like "Request or  survey."
Then clear instance cache using "cache.do " and change your language and reload the portal, you will see the translated value.
19 REPLIES 19
@ahmed-24 I tried this in my PDI and it worked, let me know if it do not work for you
@ahmed-24 did you try this?
@Raghav Sharma24  Hello! not yet i will let you know when i test it this morning. thank you so much
@ahmed-24 You can revert the changed we did to the angular template, those are not required.
Hello @Raghav Sharma24 the problem that the other label names dosn't change. have you an idea about its please?
