Trigger an event using background script.
PriyaRaj
I am having one requirement to build a notification to notify a group when the record is inserted in 'quarantine_file'. To test this notification, I need to create an event and then trigger the notification with the event.
But I haven't worked on event before. So kindly help me to trigger the event through background script so that I could test the notification as we cannot directly create a record in 'quarantile_file'.
Thanks in Advance!!
ArunavaS
You can use the following code to call an event in server side script
gs.eventQueue(<event name>, current , param 1, param 2);
Sri Harsha2
Hi @PriyaRaj,
1. Create event in the "Event Registry'.
2. In the background script write below code to trigger the event
var  grTask = new GlideRecord('task');  //glide into your table
grTask.addQuey('___'); // add your condition
grTask.query();
while(grTask.next()) { //if any record found then send notification
gs.eventQueue('Event_name',grTask,parm1,parm2); // trigger event using eventQueue() method
