Trouble fetching values of List Collector variable using For-each logic in ServiceNow
NirupamH1
In my catalog item, I am using "Account" variable which is a multi-collector variable. Now once, my request is submitted a subflow is supposed to be triggered which will run "for- each" value of Account. Now, in order to achieve this, I used For- each but whenever the flow is triggered the for-each is not retrieving any single value of Account. PFA the screenshot below:
Here although the Account value is being retrieved through "Get Catalog Variables" step, for-each is not working as it should. Kindly, suggest a solution for this.
Thanks and Regards,
Hrithik Nirupam
Hello @NirupamH1
Ohh sorry my bad.
For this use lookup multiple and give the table name and give condition as
Field_name.sys_id ISONEOF list collector
Then update multiple or create new record.
Harsh_Deep
Hello @NirupamH1
For MRVS you need to check this docs-
https://www.servicenow.com/community/workflow-automation-articles/how-to-use-multirow-variable-sets-...
Hi @Harsh_Deep ,
Your solution is valid for mvrs but my account variable is a list collector variable in which I can store multiple accounts and pass it onto the flow. Can you suggest a solution according to list collector variable type?
Hello @NirupamH1
Ohh sorry my bad.
Thank you @Harsh_Deep , it is working as accepted now.
