ā02-07-2022 06:26 AM
UI policy is not working in making the "assigned to" field on "problem" form to Mandatory. Could you plz help on this resolving this , Below is the ui policy Andalso i have increased to highest order for that ui polocy.
Service Desk
ā02-07-2022 07:09 AM
There is a Data Policy OOB which is restricting this to happen.
navigate to the below link :
https://instance.service-now.com/nav_to.do?uri=sys_data_policy2.do?sys_id=9f1b086f875b13000e3dd61e36cb0beb
Replace "instance' with your instance name.
Select the New state value as well along with other state as shown below and you should be good here:
Result:
Shloke
ā02-07-2022 07:06 AM
Try making it mandatory through dictionary if at all you want that to remain mandatory, I guess you have to do dictionary override in case field is present in task table, but still I suggest trying client script or UI policy
ā02-07-2022 06:41 AM
IT looks there has to be a conflict. Check if there are any other UI policy which has assigned to field of problem.
Thanks.
ā02-07-2022 06:53 AM
Hi Saurav,
tried with disabling other policy but it is not working.
ā02-07-2022 06:46 AM
OOB if you change the problem state to Assess using UI action the Assigned to field will be mandatory.
ā02-07-2022 06:52 AM
Hi Murthy,
can you plz tell name of the UI action
