UI policy is not working in making the "assigned to" field on "problem" form to Mandatory. Could you plz help on this resolving this .
anil4005
UI policy is not working in making the "assigned to" field on "problem" form  to Mandatory. Could you plz help on this resolving this , Below is the ui policy Andalso i have increased to highest order for that ui polocy.
There is a Data Policy OOB which is restricting this to happen.
navigate to the below link :
https://instance.service-now.com/nav_to.do?uri=sys_data_policy2.do?sys_id=9f1b086f875b13000e3dd61e36cb0beb
Replace "instance' with your instance name.
Select the New state value as well along with other state as shown below and you should be good here:
Result:
Shloke
17 REPLIES 17
Assess is the UI Action name.
Shloke
Yes šŸ™‚
shloke04
Also can you tell me when do you want to make Assigned to as mandatory , like when you create a Problem then only?
Below is the screenshot of the UI Action and Assigned to being mandatory when clicked in the Assess button:
Shloke
Hi Shloke,
Assigned to field should be mandatory whenever we open the problem record
Result:
Shloke
