UI Policy not working when moved from DEV to TEST
cgreen2
I've created a UI Policy on a catalog item however when i've moved the update set from Dev to Test the UI policy has been created (looks identical) but isn't working.
I've created a new update set in Dev - updated the Active / De Active / Active flag to see if that would work it when i moved it to Test but it's still not working.
Any suggestions / ideas please.
Don't see anything odd immediately. I assume that the UI Policy Action also looks exactly the same between dev and test?
Kind regards,
Mark
2020-2022 ServiceNow Community MVP
2020-2022 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Yes, that's what's really strange  - maybe i'll have to create a new update set, delete the UI and then re create - see if that fixes it.  It's on a record producer rather than a standard catalog item as it's the incident screen via the portal - would that cause any issues? - thanks again for your help
Create new update set and try to deactivate the existing one or delete it
Create a fresh one in your new update set and then migrate it
