Unable to execute Powershell script from ServiceNow
SNOW44
Mega Guru
Hello Community,
I have installed a mid server in my personal PC. In mid server agent>scripts>powershell>myService.ps1 created myService.ps1 . From ECC queue, I created a output record as below
1. name=mid.server.<mid_name>
2. Topic=Command
3. Name=powershell scripts\PowerShell\myService.ps1
4. Queue=output
5. state=ready
When I created a record as above in ECC queue. I'm getting error as below,
<?xml version="1.0" encoding="UTF-8"?><results probe_time="2547"><result command="powershell scripts\PowerShell\myService.ps1"><stdout/><stderr>scripts\PowerShell\myService.ps1 : The module 'scripts' could not be loaded. For more information, run 'Import-Module
scripts'.
At line:1 char:1
+ scripts\PowerShell\myService.ps1
+ CategoryInfo          : ObjectNotFound: (scripts\PowerShell\myService.ps1:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CouldNotAutoLoadModule
</stderr></result><parameters><parameter name="agent" value="mid.server.IST Mid Server"/><parameter name="signature" value=""/><parameter name="response_to" value=""/><parameter name="from_sys_id" value=""/><parameter name="source" value=""/><parameter name="priority" value="2"/><parameter name="agent_correlator" value=""/><parameter name="skip_sensor" value="true"/><parameter name="processed" value=""/><parameter name="error_string" value=""/><parameter name="sys_id" value="0a3585f12f7595106739dcb6f699b6d7"/><parameter name="sequence" value="1831bf486500000001"/><parameter name="from_host" value=""/><parameter name="sys_created_on" value="2022-09-08 07:15:53"/><parameter name="sys_domain" value="global"/><parameter name="name" value="powershell scripts\PowerShell\myService.ps1"/><parameter name="topic" value="Command"/><parameter name="state" value="ready"/><parameter name="queue" value="output"/><parameter name="ecc_queue" value="0a3585f12f7595106739dcb6f699b6d7"/></parameters></results>
Can anyone advice how to solve above error.
Thanks inadvance.
Rob_RJ
You are getting this error because your folder name "powershell scripts" is having space in the command.
because of the space system treats powershell and scripts as 2 different things.
So, Remove the space and give it a try from folder name and in command. like powershell_scripts or poershellScripts.
Rob_RJ
jaheerhattiwale
@SNOW44 You need to create a mid server script file in servicenow in "Mid Server Script Files [ecc_agent_script_file]" table.
Please mark as correct answer if this solves your issue.
