Use system property in Module arguments
10-18-2018 02:05 AM
Hello All,
I have an issue with using system property in module arguments.
Module link type is URL and argument is:
kb_feedback_list.do?sysparm_query=article.cmdb_ciINjavascript:new ScriptName().getServices(gs.getUserID());
This script include is client callable and works fine for admin. However not for other users. After debugging I have realized that the issue is with system property. Since this is client callable, I do not think I can use gs.getProperty so I have built method to do that:
getSystemProperty: function (propName) {
var gr = new GlideRecord('sys_properties');
var value;
gr.addQuery('name', propName);
if (gr.next()) {
value = gr.getValue('value');
return value;
Does it mean that if user doesn't have access to sys_property table he cannot get it via script either? Another thing I have tried is to add property to method argument like so:
kb_feedback_list.do?sysparm_query=article.cmdb_ciINjavascript:new ScriptName().getServices(gs.getUserID(), gs.getProperty('property.name'));
But this does not work for anyone, not even admins. Which seems weird that I can call gs.getUser here but not getProperty.
How can I solve this issue? I do not want to hardcode property value into script. Thank you.
10-18-2018 03:10 AM
Hi Maros,
Yes its true that if a user does not have access to a table, he/she can not retrieve it via code as well. I would suggest to use a display business rule on kb_knowledge table and pass the property in scratch pad and try using the same scratchpad variable in URL.
Business Rule:
g_scratchpad.my_property = gs.getProperty('propName');
Try g_scratchpad.my_property in URL
Hope it helps.
Rajnish
10-18-2018 07:12 AM
Hi, I have tried this and it does not work. What setting should display business rule have to be able to use scratchpad in Module argument?
10-18-2018 03:47 AM
So why exactly are you not using gs.getProperty to read the property in your script? Why are you using a gliderecord here?
10-18-2018 04:28 AM
As per community question:
"You cannot use gs.getProperty() client-side..."
Of course I have tried it, but it does not work.
