User criteria match all on location and group
Daniela18
Hi
I want a user criteria to both match user group and a location that is on the user.
But this doesn't work. Do I have to script? I am novice at scripting, How would such a script look?
I would encourage to have step by step debug
1) check if member of Hardware is able to access the catalog
Keep Script as: Test with user
answer = gs.getUser().isMemberOf('Hardware');
Next
2) check if user's location condition is satisfied
Keep Script as: Test with user having that location
answer = ifScript();
function ifScript(){
var user = new GlideRecord('sys_user');
user.addQuery('sys_id', gs.getUserID());
user.addQuery('location', '25ab9d720a0a0bb300793d3a6b891f82');
user.query();
var locationValid = user.hasNext();
return locationValid;
3) Now combine both the codes and check by adding logs
If my answer solved your issue, please mark my answer as ✅ Correct & 👍Helpful based on the Impact.
19 REPLIES 19
not working. baah this is driving my crazy and seems crazy hard
Next
user.query();
Thank you. I now tried again and it finally worked
Jaspal Singh
Mega Patron
Hi Daniela,
Juse ensure below.
Else, it will try to match any of condition from above & then display it.
Yes. I've already made sure.
