User should not be able to select same user two times in Multi-row variable set.
Brijmohan
I am stuck on one requirement. There is one Multi-row variable set in catalog item where requester can add up to 100 users but should not be able to add the same User twice".
How I can restrict this? Please suggest.
Thanks in advance!
Mohith Devatte
Tera Sage
Hello ,
For avoiding duplicate entries you can create an on submit client script inside MVRS
PLease use the below script this will work for sure
function onSubmit() {
    var value = parent.g_form.getValue("<mrvs name>"); // change mrvs name
    var arr = JSON.parse(value);
    if (searchExisting(g_form.getValue("<column name to check>"), arr)) { // change column name
       alert('There are duplicates please remove those before submitting');
       return false;
function searchExisting(keyColumn, newArray) {
    for (var i = 0; i < newArray.length; i++) {
        if (newArray[i].<column name to check> == keyColumn) {  // change column name
            return true;
    return false;
Please accept the solution if it helped you and close the thread. This might help others too with same query
9 REPLIES 9
Hi Mohit,
Though type is selected as ALL, the code isn't working in Service Portal & we have the error  "There is a JavaScript error in your browser console". Can you please suggest on this ?
What is the resolution for this ? Can you guys let me know. I am facing the same issue
Allen Andreas
Done, thanks for letting me know.
@Allen Andreas Your provided link is not available , could you please send that here again which might be helpful for us.
