Using variable to set due date on task ticket - date is setting to the variable - 1 day. Why?
NancyS1
I have a Due Date field on my catalog form, named csc_due_date. In the workflow on the Create Task activity, I'm using the due date on the task ticket. I'm using this script:
task.due_date = current.variable_pool.csc_due_date;
The due date field gets updated, but it's off by a day. For example, if I pick 1/15/2022 as my due date on the form, the ticket gets a due date of 1/14/2022.
I don't understand why I'm off by a day. Any help appreciated.
Ankur Bawiskar
possibly because of timezone
use this
task.due_date = new GlideDateTime(current.variable_pool.csc_due_date);
@Naresh_5120
Can you please post a new question and tag me there as this is older thread
Maharshi Chatte
As Ankur said this can be a timezone issue. We also faced this issue a number of times because by default the script takes the system timezone  . If you want you can change your timezone also from your profile and check once because we also did the same.
Maharshi
NancyS1
I'm afraid my mistake was in not noticing the catalog field was a Date field while the Due Date field on the task ticket is a Date/Time field. Once I changed the field type, I was able to use Ankur's code:
Thanks for the help!
@NancyS
Did you mistakenly marked your own response as correct?
Would you mind marking my response as correct if I was able to help you.
