Variable attribute ref_ac_columns not working for Reference variable with Knowledge table as reference
abhis42
I have given below attributes in a reference variable where reference table is 'kb_knowledge'
 But Short Description is not getting displayed.
 Where as when reference table is 'sys_user' and attribute is 'ref_ac_columns=user_name;email' its working fine.
What is the issue here.
Is there any other way to achieve it without modifying global data.
Abhishek B
pratikjaiswal
Use this as a whole in the attribute :
ref_auto_completer=AJAXTableCompleter,ref_ac_columns=u_description,ref_ac_columns_search=true
SHould work.
Let me know if this helps
Mark the answer correct if this helps!
Pratik
@pratikjaiswal Your answer should be marked as the answer.
Please mark the answer as correct if it helped you. I'd appreciate it.
Pratik
