‎02-07-2025 03:02 AM
I have created a catalog variable which refers to requested item table and set the simple reference qualifier as state is closed complete and catalog item is 'abc'. In addition need to display the column opened, requested for and 'select business application' which is a variable of the catalog item 'abc'.
I have set the Variable attributes like:
ref_ac_columns=opened;requested_for;select_business_application,ref_ac_columns_search=true,ref_auto_completer=AJAXTableCompleter
Opened and requested for are populating but business application is not populating.
Could you please help me out.
Thanks&Regards,
Abhisek Chattaraj.
‎02-07-2025 03:07 AM - edited ‎02-07-2025 03:21 AM
Hello @abhisek
You can use below:
ref_ac_columns=number;opened_at;variables.variablename;
If the above does not work you can make the field as select box instead of reference and follow the steps mentioned in the below thread by @Bernd Hoffmeier
Show RITM variable values as variable attributes i... - Page 2 - ServiceNow Community
Solved: Re: Show catalog item variables in columns on refe... - ServiceNow Community
Thanks & Regards
Viraj Hudlikar.
‎02-10-2025 02:10 AM
I tried with Lookup select box and it showed me the variable value
I had 2 RITMs with that variable populated and it showed me
Use it in Lookup label field(s)
I was able to search as well using that variable value
I believe I have answered your question.
‎02-10-2025 02:12 AM
check my below latest comment and it worked for me with Lookup select box
‎02-10-2025 02:14 AM
You are correct. Using lookup select box it is working but in my case the problem is Lookup label field(s) has a limitation. It is not allowing me to mention all the variables here what I need to populate as per the requirement.
Thanks&Regards,
Abhisek Chattaraj
‎02-10-2025 02:57 AM
Glad to know that my approach worked.
Please ensure you keep only the limited and required variables. Adding more variables/columns there will have performance impact.
‎02-13-2025 02:27 AM
Hope you are doing good.
