Variable Read Only
Bishal Sharma
Can you help me to make below particular variable read only when state is closed complete or closed incomplete or closed skipped. (screenshot attached)
shloke04
Hi @Bishal Sharma
This can be done using a Client Script on Catalog Task Table. You just need to write an On Change Client Script on Catalog Task Table on State Field and use the script below:
This client script will take care of both scenario when state changes also after you save the form it will validate for the state value to make it read only.
Script:
        var getState = g_form.getValue('state');
        if (getState == 3 || getState == 4 || getState == 7) {
            g_form.setReadOnly('variables.checkbox', true);
    if (newValue == 3 || newValue == 4 || newValue == 7) {
Screenshot for reference:
Result:
Script is an tested one in my PDI and will work for you as well for the query mentioned.
Shloke
Shloke
Instead of on submit, configure on load client script.
Sachin
Same story with onLoad.
Try below code.
Also, use debugger in your client script debugging to debug further.
https://developer.servicenow.com/dev.do#!/learn/learning-plans/quebec/new_to_servicenow/app_store_learnv2_scripting_quebec_debugging_client_scripts
function onSubmit() {
var statevalue = g_form.getValue('state');
if((statevalue == '7') || (statevalue == '4') || (statevalue == '3'))
g_form.setReadOnly('Additional_software_requirements', true);
Sachin
NIkhil Chaurasi
To access those variables, you need to use variables.VARIABLE_NAME & in UI Policy, mark it as read only.
g_form.setReadOnly(variables.VARIABLE_NAME);
shloke04
Hi @Bishal Sharma
Script:
Result:
Shloke
Shloke
