‎06-13-2022 01:21 AM
we have implemented virtual agent for itsm and we are planning to do it for hr onboarding
can we have different branding for two personas?
currently we have one branding for bot when i click on virtual agent its redirecting to same branding?
Virtual Agent
‎06-18-2022 07:01 AM
If you would switch to using the preferred ServiceNow method of using Service Portal Agent Chat configuration (embedding a widget like you do is a legacy method), then you could just assign roles to the Service Portal Agent Chat configuration record.
Kind regards,
Mark
2020-2022 ServiceNow Community MVP
2020-2022 ServiceNow Developer MVP
‎06-13-2022 09:21 PM
Here we have single portal ,i am new to VA the topics of HR and IT are combined
can you please tell me steps to implement this
we have both HR and IT VA on same portal and we want different flow for both
‎06-13-2022 09:27 PM
Or are you using a (legacy) Service Portal widget (maybe embedded in a header or footer) and not Service Portal Agent Chat configuration
i have embedded in portal footer and its showing same chat icon and configuration on onboarding page as well
‎06-13-2022 11:28 PM
If embedded to a widget header/footer, than most lickely you did this with a small bit of HTML code?
For example:
<widget id="sn-va-sp-widget"></widget>
Is that correct? If so, you can expand this so it uses a specific branding record:
<widget id="sn-va-sp-widget" options='{"va_url_params":"&sysparm_branding_key=id_of_your_branding_record"}'></widget>
Ofcourse you would need to apply a different header/footer to both portals.
Kind regards,
Mark
‎06-14-2022 12:57 AM
Hi Mark,
Thanks for guiding on this,how can he handle this if we are ussing one portal for both hr and it.
‎06-14-2022 01:05 AM
That was my initial question?!
So what are you using, 1 portal or 2? You responded with 2?
Anyway, if 1 portal... it starts with your logic. What is your expectation exactly? How are users then using your portal, your virtual agent? How do you know, if it should be the Virtual Agent client for HR or the one for not-HR? What is the logic there, for example based on roles?
Kind regards,
Mark
