‎01-25-2022 03:03 AM
I am using a schedule job, where I am querying the records from a table and doing some action for the retrieved records. Now I want to have delay between each record to get that action done (one after the other after few seconds). Could anybody has an idea?
‎01-27-2022 11:28 PM
Hi Ajay,
Yes, you can use that way. You would need to use it after you write gr.update() statement so that system will keep delay after every update as per your requirement.
Note: Consider delay timing before executing script e.g. If you are updating 1lakh records then keeping 1 seconds delay for each record will take more than 24hours.
Please mark this as Correct or Helpful if it helps.
Thanks and Regards,
Abhijit
Abhijit
ServiceNow MVP
‎01-27-2022 11:01 PM
Hi
Can I place it simply at the end of the script?
while(gr.next()){
//-----some action-----//
gs.sleep(1000);
‎01-27-2022 11:14 PM
Yes that will work just fine.
Hi Ajay,
Thanks and Regards,
Abhijit
Abhijit
ServiceNow MVP
