wait for condition in subflow
Negha1
I have a subflow, where i wanted to add wait for condition with incident state to be checked in the condition.
but the table field i cannot select in the wait for condition action in subflow, the drop down is not working. without selecting table, i cannot give condition to check the state
why it is not coming, or what to do next?
faiqabatool
Hi @Negha1 ,
You can do any of the following to resolve your issue:
1- Select the Table in the Table field first.
2- You can select the Record value by drag and drop the data pill from the Right hand side panel (Data panel).
Hope this helps!
If my solution helps, mark it as helpful and accept the solution. It will help the future readers.
Thanks & Regards,
Faiqa Batool
