Waiting for flow execution data - Flow designes
kamma_priya
Giga Expert
We are using flow designers for Change Management. When Change is submitted for Approvals flow is triggered and we got the first level approvals and we are not getting the second level approvals.
when we click on SHOW FLOW. We are getting below error "Waiting for flow execution data".
Priya
Hi Priya,
Please refer the link below if it helps
https://community.servicenow.com/community?id=community_question&sys_id=26276fcb1bd318108672ea89bd4bcbb4
Please mark the response as Helpful/Correct, if applicable. Thanks!
kamma_priya
Giga Expert
Hi Nikita,
I have tried refreshing the flow designer and still able to see the same issue.
Priya
Have you tried by deactivating the flow and then re-activate?
Hi Nikita,
We have this issue in production environment where same flow is working for other change requests and have this issue in only one change request in production environment.
I didnt tried saving or deactivate and active flow designer as we dont have priviliege to do in production environment
Priya
