What is difference between After and Async Business Rules please explain with real time scenario
SreenadhChenna
What is difference between After and Async Business Rules please explain with real time scenario.
Please let me know with the Example.
AndersBGS
Hi @SreenadhChenna
Async Business Rules are similar to after rules in that they run after the database commits a change. Unlike after rules, async rules run in the background simultaneously with other processes. Async Business Rules allow ServiceNow to return control to the user sooner but may take longer to update related objects.
best regards
Anders
Saurabh Bhoi
After Business Rule: Runs after a record is inserted, updated, or deleted, ensuring that all database operations are complete before executing. It runs synchronously, meaning the user waits for the rule to finish before continuing.
Asynchronous Business Rule: Runs in the background after the current transaction is complete, allowing the user to continue without waiting. It's ideal for non-urgent tasks like sending notifications or updating related records.
Atul111
One of the good example of After and Async Br is:
Customer requirement is to Resolved all the child incidents once the Parent Incident Resolved.
After BR - Update action, User will be on the same page until all the child records will not resolved after resolving the Parent Incident.
Async BR - User will be redirected to the next page and there will be a schedule job created and will be queued, once the system will be free it will be executed on backend.
Please let me know if any doubt.
VaishnaviK3009
Hi @SreenadhChenna !!
After Business Rule
After Business Rules run immediately after the record is committed to the database, within the same transaction.
Key points:
  • Runs synchronously
  • User waits until the rule finishes
  • Executes right after the save
  • Suitable for lightweight logic
 When to use
Use an After Business Rule when the action must happen immediately after saving the record.
 Real-time scenario
Send a notification when an Incident is resolved
You want to ensure the Incident is already saved as Resolved before triggering the notification.
Example
Table: Incident
When: After
Condition: State changes to Resolved
if (current.state == 6 && previous.state != 6) {
    gs.eventQueue(
        'incident.resolved',
        current,
        current.caller_id,
        current.number
Async Business Rule
Async Business Rules run after the record is saved, but in a separate background thread.
Key points:
  • Runs asynchronously
  • User does not wait
  • Improves performance
  • Best for heavy processing
 When to use
Use an Async Business Rule when the logic is time-consuming or affects many records.
 Real-time scenario
Close all related incidents when a CI is retired
Updating many related records in an After rule would slow down the save action.
Example
Table: cmdb_ci
When: Async
Condition: State changes to Retired
inc.addQuery('cmdb_ci', current.sys_id);
inc.query();
while (inc.next()) {
    inc.state = 7; // Closed
    inc.update();
The CI saves instantly, and the related updates run in the background.
Mark this as Helpful if it clarifies the issue.
Accept the solution if this answers your question.
Vaishnavi
Associate Technical Consultant
