What is the difference between execution plan and workflow?
Options
11-21-2017 07:00 AM
help me
Options
11-21-2017 08:16 AM
Hi Venu,
execution plan is mostly used in servicenow express and describes how catalog item should behave.
workflow is used in the actual servicenow which may have approval activity, task creation etc.
Mark Correct if this solves your issue and also hit Like and Helpful if you find my response worthy based on the impact.
Options
11-21-2017 08:20 AM
Hello Pasunooti.
Please check :
