what is the difference between getFields() and getElements()?
Prasanthi1
Giga Contributor
What is the difference between getElements and getFields method.
Pls explain with examples...
Hi @Prashanthi
getFields() getElements()
getFields is a gliderecord method getElements is also a gliderecord method
getFields() works only in Global application not in scoped getElements works for both scoped applications and global
It returns an array of field names for the specified GlideRecord it returns an array (if in scope) or an ArrayList (if in global) of all of the elements on the record.
script examples
getFields:
var queryString = "priority=1^ORpriority=2";
var now_GR = new GlideRecord('incident');
now_GR.addEncodedQuery(queryString);
now_GR.query();
now_GR.next();
var gRU = new GlideRecordUtil();
var fieldList = gRU.getFields(now_GR);
gs.info(fieldList);​
output:
sys_id,skills,closed_by,assigned_to,contract,category,escalation,state,reassignment_count,location,
time_worked,order,due_date,number,upon_approval,sys_tags,sla_due,follow_up,reopen_count,notify,business_stc,
caused_by,rejection_goto,assignment_group,comments_and_work_notes,incident_state,opened_at,parent_incident,
business_service,wf_activity,calendar_duration,group_list,caller_id,comments,priority,sys_updated_by,
variables,delivery_task,resolved_at,sys_updated_on,parent,active,opened_by,expected_start,watch_list,
company,upon_reject,work_notes,sys_created_by,additional_assignee_list,approval_set,cmdb_ci,user_input,
sys_created_on,close_code,contact_type,resolved_by,rfc,approval_history,activity_due,severity,child_incidents,
,subcategory,work_end,closed_at,close_notes,variables,business_duration,knowledge,approval,sys_domain_path,
sys_mod_count,problem_id,calendar_stc,work_start,sys_domain,correlation_id,sys_class_name,short_description,
impact,description,correlation_display,urgency,made_sla,delivery_plan,work_notes_list
_______________________________________________________________________
getElements :
simple script for output:
var incident = new GlideRecord("incident");
incident.addQuery('sys_id','INC SYS_ID FOR TESTING');
incident.query();
if(incident.next()){;
var elements = incident.getElements();
gs.print(elements);
output:
you will get field values of that particular record in array
Another script with all details:
You can refer this to use for both global application and scoped applications
incident.addActiveQuery();
incident.setLimit(1);
incident.query();
incident.next();
if (typeof elements.size != 'undefined') {
       //we are in global scope, so iterate
       for (var i=0; i<elements.size(); i++) {
               var element = elements.get(i);
               gs.info("Element label is {0}, name is {1}, value is {2}", element.getLabel(), element.getName(), incident.getValue(element.getName()));
       //we are in scope, so loop over the array
       for (var i=0; i<elements.length; i++) {
               var element = elements[i];
Hope this helpfuls you understand,if so please mark the relevant answer correct and helpful.
BR,
Harika
Thank you Harika for your excellent explanation. It is very helpful for me.
Thank You
Prasanthi
Sushma Dhandge
Giga Contributor
Hi @prashanthi
getElement
You can access a GlideElement from a server-side GlideRecord object (for example, by using gr. number ), or by using the getElement method of a GlideRecord object. Best practice dictates that you always use the getter and setter functions: getValue() , and setValue() if you want to get the value of the field.
getFields(GlideRecord gr)
Returns a list of all the fields in the specified GlideRecord. A GlideRecord instance positioned to a valid record. An array of field names for the specified GlideRecord
sushma
Here I a asking getElements() not getElement().
Thank You
