What is the difference Between gr.initialize() and gr.newRecord() ?
SohamTipnis
Can somebody clear my doubt on this? and  Which is more preferable?
Thanks & Regards,
Soham
3 ACCEPTED SOLUTIONS
Shashank_Jain
@SohamTipnis ,
gr.initialize()
  • Used after you already created a GlideRecord object and selected a table.
gr.newRecord()
  • Creates a new empty record for the table in one step.
  • Internally, it calls initialize(), but also does some extra setup:
    • It executes any business rules or default values defined for when = new or Display Business Rules.
In simple words if I have to explain this to you -
  • Use initialize() when you just want a blank record quickly (no defaults).
  • Use newRecord() when you want a record with defaults and business rules applied, just like creating it from the UI.
  • newRecord() behaves like clicking "New" on the Incident form.
  • Any default values (like Priority = 3, State = New) or "on new" Business Rules will run.
  • So the record gets created with those defaults already set.
Hope it helps!
If this works, please mark it as helpful/accepted — it keeps me motivated and helps others find solutions.
Shashank Jain
Shruti D
Hello @SohamTipnis,
  •  gr.initialize()
Purpose: Prepares a new record for insertion.
What it does: makes a new empty record with no values filled in. It resets everything so you can start fresh.
Use: When you want to insert a new record into a table.
Example:
var incidentGR = new GlideRecord('incident');
incidentGR.initialize(); // starts a new empty record
incidentGR.short_description = 'Test incident';
incidentGR.insert();
 This is used to create a new record manually.
  • gr.newRecord()
Purpose: Similar to initialize(), but also pre-populates default values, including ones from the dictionary, default values, or Business Rules.
What it does: Creates a new record and sets default values based on the table's dictionary and from client scripts or UI policies (on the server).
Use: When you want a new record with default field values already set.
Example:
incidentGR.newRecord(); // new record with default values
gs.info(incidentGR.category); // might show a default value
So in short,
gr.initialize(): Creates a completely empty new record with no default values set.
gr.newRecord(): Creates a new record and automatically fills in the default values defined in the system.
Please Mark Correct ✔️ if this solves your query and also mark Helpful 👍 if you find my response worthy based on the impact.
Shruti
its_SumitNow
Hi @SohamTipnis ,
Whenever you are using gr.initialize() it creates a blank record in memory, here default values are not populated in the blank record
var gr = new GlideRecord("incident");
gr.initialize();
gs.print(gr.getValue('category'));
gr.setValue('caller_id','abedbd9a534722101ade32a0a0490ee7');
gr.setValue('short_description','Hii testing now');
gr.insert();
Run this Query you will get null output, because gr.initiliaze() is creating completely blank records in all fields
While gr.newRecord() creates a new blank record where default values are already populated in
gr.newRecord();
gr.insert();
here You will get Output as 'Inquiry' which is the default value of category field of incident table
As per Performance is Concern, it's better to use newRecord();
Warm Regards
Sumit Y
Shruti D
Hello @SohamTipnis,
  •  gr.initialize()
Example:
  • gr.newRecord()
Example:
So in short,
Shruti
Got it! 👍
Thank you @Shruti D 😀
its_SumitNow
Hi @SohamTipnis ,
gr.initialize();
gr.insert();
gr.newRecord();
gr.insert();
Warm Regards
Sumit Y
SohamTipnis
Thanks for your answer 😊
