What is the procedure to move Flow to another instance?
‎04-11-2023 11:19 PM
I want to move the Flow to another instance.
But I don't see an Export XML button anywhere.
How do I migrate?
‎04-12-2023 12:13 AM
that's correct.
Create update set, make it current
Open the flow, make some description etc change, save it, publish it.
It will be captured in update set
‎04-12-2023 12:40 AM
Thank you for the comment.
I tried, but it doesn't capture...why...?
Is there any other way?
‎04-12-2023 12:51 AM
‎04-11-2023 11:23 PM
‎04-11-2023 11:29 PM
Thank you for your comment.
If I want to migrate an already created flow, how can I capture it?
Does it come with subflows and actions as well?
