What's the best way to place a time constraint on a catalog item?
patricklatella
I need to place a time constraint on a catalog item.   For example, the item is available upon approved request, but only for a 10 day period...what's the best way to apply this constraint?
You do not need a script include to make sure that the end date is not before the start date, only the lines I added - checked and verified in my instance.
If you have all the script I provided, you should be covered.
Please make sure you added the lines to the correct script.
Also, reload the catalog item page after adding and the lines and saving the script.
If it still does not work, please share your script with the lines included.
harel
41 REPLIES 41
You will need an onChange client script that queries the cmdb_ci_computer table for the user's asset.
So:
Type: onChange
field: customer (or whatever the field the end user enters their value in)
Script:
  var computer = new GlideRecord('cmdb_ci_computer');
  computer.addQuery('assigned_to', newValue);
  computer.query();
  if(computer.next()){
  g_form.setValue('u_computer', computer.sys_id);
Note1:
This will work when the user changes the value of the field "customer". If you need the field "computer" to be be set on load of a form, copy the script to a new onLoad script and change "newValue" to you customer's field, for instance:
var customer = g_form.getValue('caller_id');
and
computer.addQuery('assigned_to', customer);
Note2:
u_computer is the field where the asset name will appear. It is a reference field to the cmdb_ci_computer table. If you want it to be a string field, change line 11 to:
g_form.setValue('u_computer', computer.name);
harel
Please mark as correct or helpful.
Also, next   time you can open a new question and get answers from smarter people
patricklatella
thanks Harel,
so the field I need to auto populate is Current Computer, variable name current_computer, do I need an advanced reference qualifier for this?
patricklatella
right now I have the Current Computer field set with an advance reference qualifier that is:
javascript: 'assigned_to='+current.variables.cur_user;
and this is making the correct choices appear when you click the magnifying glass icon...I just need the choice (if there is only one) to auto-populate
I entered what you provided and so far not working.   I also have a working script include called u_Computer_Requests_Ajax that is governing several catalog client scripts, would I need to add anything to that?
Catalog item - I missed that...
As for the u_Computer_Requests_Ajax - depends on what it does...
So you can add a catalog client script as follows (be sure to change the name of the fields according to what you have):
  g_form.clearValue('computer'); //clear the computer field in case there's something in it
  var user = g_form.getValue('cur_user'); //the current user field
  var ga = new GlideAjax('getAsset');
  ga.addParam('sysparm_name', 'asset');
  ga.addParam('sysparm_user', user);
  ga.getXML(getResponse);
  function getResponse(response) {
  var answer = response.responseXML.documentElement.getAttribute('answer');
  g_form.setValue('computer', answer);
and the corresponding script include:
Client callable: yes
var getAsset = Class.create();
getAsset.prototype = Object.extendsObject(AbstractAjaxProcessor, {
  asset : function() {
  var user = this.getParameter('sysparm_user');
  computer.addQuery('assigned_to', user);
  computer.query();
  var count = computer.getRowCount();
  while(computer.next()) {
  if(count == 1){
  var answer = computer.name;
  return answer;
      type: 'getAsset'
harel
patricklatella
thanks,
when you say (be sure to change the name of the fields according to what you have):
which fields in the code should I be sure to check?   I apologize, my java skills are limited
