When click on try it on catalog item instead of order now, Submit button should be displayed
1_DipikaD
I have a catalog item when I click on try it it shows order now,add to cart , quantity etc. But my requirement is on try it page instead of all these options only Submit button should be displayed. So for this I also tried below  catalog client script which is in 1st reply but it is not working as expected.
Also trying to display this catalog item on custom portal , how can I achieve these 2 requirements.
Plz reply asap.
@Sandeep Rajput @Ravi Gaurav @Dr Atul - LNG @Mark Manders @Ankur Bawiskar @Community Alums
1_DipikaD
To achieve this I wrote below catalog client script(onload):-
function onLoad() {
    // Change the 'Order Now' button label to 'Submit'
    var orderNowButton = document.querySelector("button.btn-primary");
    if (orderNowButton) {
        orderNowButton.innerHTML = "Submit";
        document.getElementById("oi_add_to_cart_button").style.display = "none";
        document.getElementById("sc_cart_item_list").style.display = "none";
9 REPLIES 9
Yes I have tried it . It only works on portal page but does not work on Try it page .
Hope you got my point.
1_DipikaD
# want to configure it on Try it  page not in portal.
1_DipikaD
I got solution to achieve this .
Thank you for your replies and meaningful questions which always helps me to find out best solutions.
@1_DipikaD Could you post the solution here, as it will help others.
1_DipikaD
function onLoad() {
