When does Fix Script get executed?
Vivek Vishnoi
I have a fix script to do some operations on a plugin-1 which I have put in plugin-2 "if" folder for plugin-1. Now during the upgrade, is it guaranteed that fix script will run after both plugin got upgraded. If not, then how can I make sure that fix script will only run after plugin-1 got upgraded?
anubhavritolia
Hi @Vivek Vishnoi
After you transfer an application to another instance, you can manually run any custom fix scripts you created. You can also install or repair the associated application to automatically run its associated fix scripts. Upgrading the instance also runs fix scripts.
https://docs.servicenow.com/bundle/tokyo-application-development/page/build/applications/task/t_RunF...
