When to use state model and when to use state flow
snehapatel
I am building a scoped application and defining a table extending the task table within the same. I want to define custom states and state transitions for the same. For defining state transitions, should I use state flow or state model. Kindly suggest.
Sneha
2 ACCEPTED SOLUTIONS
Nikhil Bajaj9
Tera Sage
Hi @snehapatel ,
In ServiceNow, both State Models and State Flows manage the lifecycle of records, particularly those extending the Task table. The choice between them depends on the complexity of the transitions and the need for automated actions.
State Model:
  • When to use:
When defining the allowed states and transitions for a record type. It provides a visual representation of the record's lifecycle, simplifying understanding of where a record can move next.
  • Purpose:
Primarily defines the possible states and the allowed transitions between them. It focuses on the structural definition of the workflow.
  • Benefits:
    • Clear visualization of the record's lifecycle.
    • Simplifies defining allowed state changes.
    • Helps answer questions about the distribution of records across states.
State Flow:
  • When to use:
When you need to automate actions or trigger specific events during state transitions. It adds logic and automation to the state changes defined in the State Model.
  • Purpose:
To define how transitions occur and what happens during those transitions. It can trigger manual transitions via UI actions or automatic transitions via business rules.
  • Benefits:
    • Automates actions based on state changes.
    • Enables manual transitions through UI actions.
    • Facilitates complex workflow automation.
In essence:
  • Use a State Model to define the blueprint of your record's lifecycle, outlining the states and the valid paths between them.
  • Use a State Flow to implement the automation and logic that governs how records move through those states, triggering actions and controlling the transition process.
They are often used in conjunction, with the State Model providing the framework and the State Flow providing the dynamic behavior and automation.
If my answer helped you, please mark it- solution accepted.
Nikhil Bajaj
Shashank_Jain
@snehapatel .
  1. State Flows
    • Think of it like a workflow specifically for states.
    • It controls how a record moves from one state to another.
    • Example: You can say → "If state = New, only allow moving to In Progress or Cancelled".
    • More flexible, no coding needed, good for task-based tables.
  2. State Models
    • This is more structured.
    • It defines allowed transitions in a diagram-like model (like a map of states).
    • Example: "From Open → only go to Pending or Resolved. From Resolved → only go to Closed".
    • Better for processes where you want strict control and visual transitions.
Which one should you use?
 If you just want to manage basic task states in your scoped table → State Flows are easier and built for task tables.
 If your process has complex rules with strict transitions (like approval workflows, strict compliance processes) → State Model is better.
Hope it helps!
Nikhil Bajaj9
Tera Sage
Hi @snehapatel ,
State Model:
  • When to use:
  • Purpose:
  • Benefits:
State Flow:
  • When to use:
  • Purpose:
  • Benefits:
In essence:
Nikhil Bajaj
Bhuvan
Giga Patron
@snehapatel
Go through below links for guidance,
https://www.servicenow.com/community/developer-articles/cheat-sheet-state-flows/ta-p/2327959
https://www.servicenow.com/community/itsm-forum/state-flows-or-state-model/td-p/477751
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
Shashank_Jain
@snehapatel .
  1. State Flows
  2. State Models
Hope it helps!
Nikhil Bajaj9
Tera Sage
Hi @snehapatel ,
If my answer helped you, please mark it- solution accepted. This will help future readers as well.
Nikhil Bajaj
