When user creates problem from an incident form it should auto populate field values
Gayathree Seeth
We have created new field called TYPE in the problem form which has two values
* proactive
*reactive
Now when we create problem from an incident form then it should auto populate with the value "proactive".
Suggest some ideas!!
Hi @Gayathree Seeth
Actually is way simpler then i thought in this case. You just need to add 4 marked below lines. Of course change fieldname and value 🙂
9 REPLIES 9
Hi @Gayathree Seeth
Gayathree Seeth
Thanks very much Kamil. The requirement is working now.
This was useful.
Gayathree S
Hi Kamil,
Even though i am getting the output for this code i am also getting one error.
I am using Onload client script for the problem table on other hand to autopopulate the type field as "reactive" when the problem is created from Problem-> Create New
When i use this client script my UI action code is not working. ( i.e The Type field is also getting populated as Reactive when created from an incident)
Hi @Gayathree Seeth
Did you get any solution on this? if so can you share what all configuration you did?
Thank You!
Hi @Community Alums
Sorry for very late response. Yes i have achieved this using the onload Client script.
