‎01-11-2022 07:08 PM
When using Flow Designer, the REQ Number is not populating in the RITM even though I have it in the fields. I also tried to populate the REQ Number & RITM Number in the SCTASK. I don't see anything in the Business Rules that may be causing this either (but I could have missed it).
Do you have any idea what may be causing this issue?
Thank you in advance!
Here is the flow for the RITM Update:
This is the RITM that I ran the test on:
And this is the Create TSK where I am trying to get the REQ & the RITM Numbers:
AAnd this is the task that was created:
‎01-13-2022 11:44 AM
I found the issue... For the sc_req_item, the task.number Display value was true, BUT a custom field was also set to true. When I made the custom field false, the Request Item appeared.
Thank you for your help!
‎01-12-2022 12:27 AM
I guess the problem is that you put a "Number" into the reference field instead of the sys_id. It should be enough if you fill the field with "Trigger > Requested Item Record > Request".
‎01-12-2022 12:37 AM
You went one more extra step for setting the value.
You should use use the sys_id Trigger > Requested Item Record > Request
‎01-12-2022 09:27 AM
‎01-12-2022 07:41 PM
I can see i icon for Request field so it means the value is populated
Can you check the XML of the sc_task record?
