When using Flow Designer, the REQ Number is not populating in the RITM even though I have it in the fields.
Joanne Johnson1
Kilo Expert
When using Flow Designer, the REQ Number is not populating in the RITM even though I have it in the fields. I also tried to populate the REQ Number & RITM Number in the SCTASK. I don't see anything in the Business Rules that may be causing this either (but I could have missed it).
Do you have any idea what may be causing this issue?
Thank you in advance!
Here is the flow for the RITM Update:
This is the RITM that I ran the test on:
And this is the Create TSK where I am trying to get the REQ & the RITM Numbers:
AAnd this is the task that was created:
I found the issue...  For the sc_req_item, the task.number Display value was true, BUT a custom field was also set to true.  When I made the custom field false, the Request Item appeared.
Thank you for your help!
