Where Clause to join 4 tables using database views
Poorva Bhawsar
Hi Community,
I have to join 4 tables using database views. All tables have one common field that is user id which is a reference field. How can i join this. Need help with the where clause.
Able to join it replaced sys_id with user_name in all the where clauses.
9 REPLIES 9
@Poorva Bhawsar
so all 4 tables have same field with same type?
Are you sure you have data in those tables based on this common field.
share the database view where clause screenshots
Yes data is there in this common field. What i did is i have created user id field in all the 4 tables and loaded data based on that. All 4 tables extending task table.
this is what i tried, user name is nothing but user id field. On the table i want to have user id from the ep table. But its showing me completely empty data after joining.
@Poorva Bhawsar
Hope you are doing good.
If my response helped please mark it correct as well so that it benefits future readers.
