Why plan start and end date fields are editable post Authorize state?
sekarpdkt
I am finding these two fields are editable till end. Ideally post authorized by CAB (mean in Scheduled / Implement / Review state), in case of normal change, these fields shall not be editable. Any reason why these are kept editable? I tested this in Istanbul instance. I can add UI-Policies etc, but want to know the reason behind it.
Thanks.
What we did:
1) created a UI Policy to make Planned Start & Planned End read-only if State is not New.
2) created a UI Action that:
- Returns the state back to New so Planned Dates can be changed. (Happy to provide the full script if you need it)
3) Modified oob Business rule named - SNC Approval - Reset conditions
- Business Rule will reset the workflow
Note: the business rule has lots of comments to explain how it works exactly.
For the Reset Condition we are using: if (current.state.changesTo("-5"))
so reset triggers when State changes back to New
Then we're using Option 2 in the BR:
new WorkflowApprovalUtils().reset(current, comment);
current.approval = 'not requested';
gs.addInfoMessage('Workflow has been reset since Planned Dates have been modified');
This should give you the basics
sekarpdkt
I had same issue. When I tried to push back that post approval, we shall not change the planned dates, but found that OOTB it was allowed. Now forced to do lots of customisation.
