Work note validation and updation before setting in RITM
jobin1
Before updating the RITM work note I need to check if the work note contains "ZjQcmQRYFpfptBannerEnd" and if so i need to eliminate this and pass it to RITM work note section how this can be handled?
Note: skip value logic is already working in the below script but I am unable to set the work note section with the trimmed content. also, it should not add twice I need to eliminate it and sent it only once to the work note section
tried the below before update business rule but not working
var newWorkNote = current.work_notes.getJournalEntry(-1);
gs.log("wrknt1"+newWorkNote);
var skipvalue = 'ZjQcmQRYFpfptBannerEnd';
  if (newWorkNote.indexOf(skipvalue) !== -1) {
gs.log("wrknt2");
// Remove everything before skipvalue including skipvalue
        var index = newWorkNote.indexOf(skipvalue);
gs.log("wrknt3"+index);
        //current.newWorkNote = newWorkNote.substring(index + skipvalue.length).trim();
  gs.log("wrknt4"+newWorkNote);
current.work_notes.setJournalEntry(-1, newWorkNote);
  gs.log("wrknt5");
})(current, previous);
Ankur Bawiskar
@jobin1
what came in log and till which line it's working fine?
try this line
current.work_notes = newWorkNote;
jobin1
current.work_notes if i use then also  old value will be available
i need to apply the logic before passing to work note section
