workflow user activity check code
dheeru_1994
Hi all  i have written this code in user activity if requester is inactive user so on the basis of inactive user i am running this code but only else part run that user is not found where i am doing mistake
var answer = []; var requested = current.variables.requested_name.getDisplayValue(); gs.info("Requester name is: " + requested); var grRequester = new GlideRecord('sys_user'); grRequester.addQuery('user_name', requested); grRequester.query(); if (grRequester.next()) { if (!grRequester.active) { var grActive = new GlideRecord('sys_user'); grActive.addQuery('active', true); grActive.query(); if (grActive.next()) { answer.push(grActive.sys_id); gs.info("The active approver is: " + grActive.sys_id); } else { gs.error("No active users found for approver."); } } else { gs.info("Requested user is active, no approver needed."); } } else { gs.error("Requested user not found."); }
Note after requesting item and select requester user no approver generate in logs    this message come
this message populate in logs user not found
9 REPLIES 9
in this code i am not abel to generate approver where i am doing mistake here
forget the code for now, tell me what is the goal, what are you trying to implement?
-Anurag
okay i have requirement   in catalog item  if requester is inactive user then by using of workflow  another active user should generate approver  it should achive only by using workflow
How can the requestor be inactive? How can an inactive user log in and request something?
Also if requestor is inactive, how does that impact approver? Approver doesn't depend on this.
-Anurag
i make user inactive in user table and i make variable that that is refrence type and i take user table as a refrence  then i connect workflow
