Write a script to display inactive problems with p2 incidents.
sabbani rishika
Script
12 REPLIES 12
Sagar Pagar
Have you try to do with scripting? where you stuck? can you share the script?
Sagar Pagar
The world works with ServiceNow
I've used on submit type and the below script.
 var gr = new GlideRecord('problem');
    gr.addQuery('state',4);
    while(gr.next()){
        var r = new GlideRecord('incident');
        r.addQuery('priority',2);
        r.query();
Its not getting displayed.
Ankur Bawiskar
it would be nice if you share your complete business requirement
where are you writing the script?
✨ Certified Technical Architect  ||  ✨ 9x ServiceNow MVP  ||  ✨ ServiceNow Community Leader
I'm using Client script on submit type.
